I’ve had a Vero V since launch and i’ve been loving it. Only last night i woke up to my Vero V turning on my TV and constantly rebooting. It looks like it may have some power issue.
It seems to happen every 3-4 seconds of booting, then HDMi cutting out and rebooting again. I’ve tried it on multiple TV’s but keeps happening.
Is there an issue with my Vero V or something else i could try?
Any power-hungry peripherals?
Do you have an alternative 5v/2A PSU to try? If not, try powering it by USB with an A-A cable (just as a test).
Indeed, try this as first step.
I have no peripherals attached, I’m normally watching movies through NFS through my LAN.
I will try another 5V/2A power supply
It seems to be working with another power supply!
I will watch some movies with the new power supply to test and see
Thanks for clarifying. Give it some more testing and we can replace the PSU for you
I’ve been using my Vero with the other psu without issue. So it seems to be a psu issue that was supplied with my vero.
A replacement would be awesome ![]()
You can contact support@osmc.tv to arrange this
