I’ve been using Vero V with a single external SSD connected via USB and it works perfectly
To add a new SSD I tried plugging in this product: 4 Port USB 3.0 Powered Hub - OSMC with two external SSDs connected to it. It worked for a few minutes, then Vero V crashed. Now when I plug it in it crashes instantly.
Maybe not much we can find if you have to unplug but still might show something
reproduce the issue
I crashed the device by plugging in the hub 3 times, once around 16:42, once at 16:51 and once at 16:52. After the first crash I unplugged the Vero to restart, but after the second two crashes it restarted automatically right away.
