With my new Vero V, if I skip forward or try to fast forward, the movie will just stop and the device will freeze. Cannot use the remote to stop the movie or anything, the only option is to power it off and restart it. Also, I have noticed when using the right arrow on the remote to skip, I can only press it once, wait for the video to skip and then press it again. If I try to press the right arrow button multiple times to speed up moving to a part of a movie I want to get to, then Vero will freeze and I have to physically turn the power off and back on again.
My movies are on a new QNAP NAS using SMB on a gigabit network. I did try to use NFS but after a number of attempts I have given up as I find it too complicated.
Would it be worth adding a 2.5gb usb network adapter to the Vero V to see if this would help improve the bandwidth? My guess is that it might be my network. I am using network cable not wifi.
Thanks,
Shai
