Vero V freezes during 3D MVC playback when seeking
Hi, I’ve got a Vero V (running the latest updates) and I’m having an issue with 3D MVC movies played from my NAS. The NAS is connected via cable.
Quite often, when skipping forward or back, the picture freezes and the Vero crashes. The image hangs, the audio loops the last half-second indefinitely, and the Vero becomes completely unresponsive. It doesn’t reboot on its own either; the only way to fix it is to pull the power lead. This ONLY happens during seeking, not during normal playback, and ONLY with 3D MVC films (ripped as MKV from the original 3D Blu-rays). It happens always at different points, not at the same seeking points. So far, it’s occurred about 10 times across 8 different movies.
Has anyone else experienced this problem?
Thanks for helping
Well helping is easier with debug enabled logs
Hi, I’ve really tried to send the log data, but I failed. Via MyOSMC, the upload always gets stuck at 95%, and via Putty, it hangs at ‘Masking private information’.
What should I do?
Do you know how large the log is?
If possible, reboot twice before uploading the log to shrink the log size.
You mean, reboot twice also AFTER reproducing the issue?
For testing, i deactivated the logging, reproduced the issue und uploaded the logs, wich works. Maybe that helps. But i will also try what you said. The movie was Titanic 3D
https://paste.osmc.tv/egosigogak
