Vero V hard reboots (kernel panic in parser_dynmic_metadata) when starting 4K HDR playback after 1 Nov update
Hi all,
Since updating my Vero V on 1 November 2026 (via My OSMC), it hard-reboots when I start 4K HDR playback. Before the update, the same file played fine (last good playback: Saturday 31 October).
What happens
  • I start an HDR film and, within a few seconds, the Vero does a full hard reboot (no frowning face, no clean shutdown).
  • It happened twice in a row on 2 November with the same file. On another attempt, Kodi segfaulted (exit code 139) right after a seek at the start of playback, instead of the whole box rebooting.
  • SDR content plays fine.
Crash dump (/var/lib/systemd/pstore/console-ramoops-0)
Unable to handle kernel paging request at virtual address ffffff80128af000
Internal error: Oops: 96000007 [#1] PREEMPT SMP
Modules linked in: dovi(POF) 8021q 8822cs ...
CPU: 0 PID: 0 Comm: swapper/0 Tainted: PF          O    4.9.269-93-osmc #1
Hardware name: VeroV (DT)
PC is at parser_dynmic_metadata+0x4c4/0x6e8
LR is at parser_dynmic_metadata+0x434/0x6e8
 vpp_matrix_update+0x248/0x1780
 amvecm_matrix_process+0x2b0/0xc0c
 amvecm_on_vs+0xdc/0x464
 vsync_isr_in.constprop.0+0x285c/0x5fdc
 vsync_isr+0x2c/0x3c
Kernel panic - not syncing: Fatal exception in interrupt
reboot reason 12
The journal isn’t persistent, so I can’t tell for certain which of the reboots this dump belongs to. Only one dump was saved.
Versions (dist-upgrade on 2026-11-01)
  • vero564-kernel-osmc 3.9.322 → 3.9.336 (image 4.9.269-80-osmc → 4.9.269-93-osmc; the -80 image is still installed)
  • vero5-mediacenter-osmc 21.2.0-1 → 21.3.0-7
  • vero5-userland-osmc 1.3.0 → 1.9.0
  • vero5-bootloader-osmc 1.3.0-1 → 1.5.0-1
  • vero5-device-osmc 1.0.3 → 1.0.5, vero5-secureosmc-osmc 1.7.0-1 → 2.1.0-1
  • apt shows no newer packages available as of 2 November.
Setup
  • Vero V → Denon AVR (2019, EDID “DENON-AVR”) → TV
  • Sink HDR caps: HDR10 and HLG yes, HDR10+ no, Dolby Vision VSVDB v2
  • Kodi HDR settings at factory defaults: videoscreen.hdrcaps = Auto, videoplayer.amlhdrmodes = Auto
  • File: 4K HEVC (3584x2160, 23.976 fps), plays as HDR10 output, TrueHD 8 ch passthrough, over SMB
Unrelated issue (now fixed): after the update I also had short black flashes every few seconds, including in the GUI. They went away after I turned off “Force 4:2:2” (videoscreen.force422 → false; it had been enabled).
I found what looks like the same crash in Vero V Problems with HDR10+ content, where a fix was mentioned in July. Is that fix in 3.9.336, or is this a different issue? Is there anything I can try (staging, or a safe way to go back to the previous kernel)?
Happy to upload full logs if needed.
Thanks!
Hi, a debug log set will certainly be required. Since you can reproduce the issue so easily, could you also please create a 30–60 second clip of the video which also let crash your system and share it via a hosting service (e.g., Google Drive, OneDrive, etc.)?
This will at least allow us to quickly determine whether we can reproduce the issue on our own systems or if it is isolated to your specific system/setup.
If you have any questions about how to generate a debug log set, just let me know.
A full set of logs will be useful; not just the ramoops data.
As @JimKnopf – if you have a clip that can trigger this issue that would also help a lot.
Thanks both! Here’s what I’ve got so far.
Logs (debug logging enabled): https://paste.osmc.tv/awuvogurek
pstore dumps from the two hard reboots on 2 Nov: https://paste.osmc.tv/azafaramis
Both are the same oops, PC is at parser_dynmic_metadata+0x4c4/0x6e8 (via vpp_matrix_update → amvecm_matrix_process → amvecm_on_vs → vsync_isr):
  • 22:25 CET, uptime 1833 s, Comm: ActiveAE
  • 22:26 CET, uptime 79 s, Comm: swapper/0 (this is the one I posted before)
Both happened within seconds of starting playback of the same film.
What I tried today (debug logging on, persistent journal enabled):
  • With the box up for about 12 hours: 10 starts of the same file (from the beginning and resuming at 2–5 min). All played as 2160p23.976 HDR10 with no crash.
  • After a clean reboot: the first play + stop crashed Kodi (segfault, exit code 139) about 49 s after Kodi started. It happened on stop, during the switch from 2160p24 back to 1080p60 (last lines: “Detected HDMI switch”, then GLES re-init). Same as the Kodi segfault on 2 Nov at 22:17. Unfortunately, a later reboot rotated out that session’s debug kodi.log. The segfault itself is in the journal for the 11:02 boot.
  • I haven’t managed to reproduce the kernel panic itself today.
Clip: https://drive.google.com/file/d/1TiYvOMkNqQWz2Txn-RQVrNQ01aiLmUWQ/view?usp=sharing
65 s stream copy (no re-encode) starting at about 3:45. HEVC Main 10, 3584x2160, plain HDR10: ffprobe shows only mastering display + CLL metadata, with no HDR10+ or Dolby Vision RPU. Audio is TrueHD 7.1 and AC3, plus PGS subtitles. I played it three times from local storage right after a fresh boot, with no crash, so it may not trigger it on demand.
Correction to my first post: the file was added to my library on 1 Nov, shortly before the update, so I can’t confirm it played on the previous version. The film I watched without problems on 31 Oct was a different one.
Is the parser_dynmic_metadata fix mentioned in the HDR10+ thread in July in the current stable kernel (3.9.336 / 4.9.269-93)? Staging seems to have 3.9.347. Should I try that?
Thx. I tried your clip on a Vero V with latest/greatest OSMC release and on a Vero V with OSMC development staging. I tried all subtitles and all audio tracks but could not create any problem on both systems.
The kernel crash logs show to me that these are not related to the video material you provided since in all crashes the audio type was set to DTS HD MA a second before the kernel oops but your clip only contains Dolby audio tracks namely a track with Dolby TrueHD with Dolby Atmos and and an AC3 audio track.
Thanks Jim, good catch on the DTS-HD MA. You were right that the clip I sent wasn’t the file behind the kernel panics; my mistake. The two panics on 2 Nov were from a different 4K file, The Princess Bride (2160p UHD remux, HEVC HDR10 + HDR10+ (SMPTE 2094-40), DTS-HD MA 5.1). In the Mood for Love (plain HDR10, TrueHD) only causes the Kodi segfaults I mentioned.
I’ve now reproduced the panic reliably and narrowed it down. HDR10+ triggers it, not DTS-HD MA:
Test (played from local storage) Result
The Princess Bride, full file (box up 2.5 h) Hard reboot within ~1 s of the switch to 2160p24
60 s stream-copy clip of it (HDR10+, DTS-HD MA) Hard reboot
Same clip, DTS-HD MA re-encoded to AC3 (video untouched, HDR10+ kept) Hard reboot, with AC3 shown as the audio type in the dump
HDR10 video without HDR10+ (In the Mood for Love) + the DTS-HD MA track from the clip Plays fine
HDR10+ clip with videoscreen.hdrcaps = HDR10 only Hard reboot
HDR10+ clip with videoplayer.amlhdrmodes = HDR→SDR Hard reboot (before the mode switch)
Every dump shows the same PC is at parser_dynmic_metadata+0x4c4/0x6e8. The new dumps are here: https://paste.osmc.tv/eqaxopuqaz (full film, AC3 variant, HDR10-only variant)
My display chain doesn’t support HDR10+ (EDID: HDR10Plus Supported: 0), so it looks like the dynamic-metadata parser runs and crashes regardless of sink capability or settings.
Also, Kodi’s history shows this same file was played on 22 Sep, when the box was still on the previous kernel (4.9.269-80). So it may be a regression in 4.9.269-93 (3.9.336).
Clip that triggers it: https://drive.google.com/file/d/11XkZ-6ViNhefhInROLOG0qYH-gjiaz2D/view?usp=sharing
60 s from 5:00, stream copy, HEVC Main 10 HDR10 + HDR10+, DTS-HD MA 5.1.
Is the parser fix grahamh mentioned in July (in the HDR10+ thread) in staging (3.9.347)? Happy to test staging if you think that’s the way to go.
TBH I can’t remember what we did in July. If I run the latest kernel I’m working on that clip plays fine. If you try staging, just update the kernel, not Kodi, as the two are incompatible atm.
Thanks Graham. I installed only the staging kernel (vero564-kernel-osmc 3.9.347 / image 4.9.269-104-osmc) and kept Kodi on 21.3.0-7 from stable. I added the devel repo only for that install and removed it straight after.
Kernel panic: fixed for me. On 4.9.269-104, the HDR10+ material that panicked every time on -93 now plays:
  • The Princess Bride clip (HDR10+, DTS-HD MA): OK
  • The same clip with AC3 audio: OK
  • The full film from SMB, from the start and resumed at 30 min: OK
  • Resumed at 5 min: no reboot or panic, but Kodi segfaulted (see below)
  • No new pstore dumps since switching kernels
Still there: Kodi segfaults (exit code 139). Kodi itself still crashes now and then. The box doesn’t reboot; mediacenter restarts it. Today’s instances:
  • 11:03, on -93: about 1 s after stopping 4K HDR10 playback, during the 2160p24 → 1080p60 switch
  • 20:47, on -104: about 23 s after stopping a 4K clip, back in the GUI
  • 21:17, on -104: 16 s into the full film, resumed at 5 min
I kept the debug kodi.log for the 21:17 crash this time: https://paste.osmc.tv/woqekojuwa
The last lines before it dies are skin widget / helper scripts (script.skin.helper.widgets, script.embuary.helper). I’m using a modded Titan Bingie skin, so it could be skin- or add-on-related. Would a test with Estuary or a clean profile help narrow it down?
Big thanks to both of you, Jim and Graham, for the quick and patient help. Spotting the DTS-HD MA in the dumps is what cracked it, and the staging kernel has my HDR10+ films playing again. Much appreciated!
Better still, try with the OSMC skin :smiley:
