I am writing to request assistance with my Vero V. Unfortunately, the device appears to have suffered a hardware failure: it will no longer read the hard drive, will not boot, and is unresponsive to factory reinstall attempts via SD card. -
When I try to update the library, I received this message. a. OSMC: Open-Source Media Center Kodi login: -
When I try to play an audio file I receive an unhappy face.
It sounds that OSMC (means the GUI on the TV is still running)?
First path for resolution would be to provide log via MyOSMC.
reproduce the issue
upload the log set (all configs and logs!) either using the
You wrote to me on the support address about this a few days ago.
As advised, Vero V doesn’t ‘understand’ the OSMC installer EXE. You need to run this program on your PC to create reinstallation media for the Vero V itself.
Please see Reinstalling OSMC - Vero V - OSMC.
