It’s difficult to tell what would work. Loads of devices claim ‘4K60Hz’ support but are coy about whether that’s under HDMI 1.4 (ie 420 8-bit max) or HDMI 2.0 with support for 600MHz clock. (Note that ‘HDMI 2.0’ does not necessarily imply 600MHz support.) A capture card that supports the latter is $$$$ for example.
Yeah, that’s why I bought the ugreen one, assuming the one I had was insufficient, but ended up having the same problems - both listings claim to support HDMI 2.0. Don’t want to buy a 3rd “4k60” one without any guarantee of it working, and the “4k120” ones seemed expensive and/or thin on the ground, for something I in theory don’t need
If they don’t support 600MHz then they should modify the EDID and everything would be fine, but that doesn’t seem to be happening.
We’ll get back to you.
