Vero V no HDMI output and network connection
Today a fourth Vero V has arrived to replace the last Vero 4K I am using. I really like the osmc platform. So I do have some experience, but despite can’t solve an issue with a Vero V which has been delivered in January,
I have been using this problematic Vero V for about two weeks now, but at this moment it doesn’t produce any HDMI signal or working network connection. So, it is useless at this moment unfortunately.
I have tried to reinstall from scratch with a new image, but this doesn’t work. It doesn’t respond and no HDMI output. Tried SSH, but no working network connection. Etc. etc. So nothing I can do?
Before this issue this specific Vero V gave me some other issues also. While using the interface it happened twice the unit gave white/gray noise on the TV instantly. After removing the power and connecting it again the issue was solved. This happened twice. Last evening when turning on the TV I got the message “no signal”. Removed power from the Vero V to restart….but still no signal. Tried reinstalling, SSH, nothing works so it looks like the Vero V has “died”?
I do find it on my network after some searching, but with a strange IP address (169.254.35.114) out of the normal range I use. I can ping this IP address, but SSH isn’t possible unfortunately.
Connected the Vero V which arrived today instead of replacing my last Vero 4K. This Vero V works instantly with the same HDMI, power and network cable. So they aren’t the problem.
Any idea what is going on? Can this be solved or is a replacement needed?
When you see an IP address of 169.254.x.x it means that it didn’t find a DHCP server so it assigned its own IP address.
Given that you have ruled out a PSU issue and already tried a full reinstall I’d suggest that you have done as much as you can and should email support@osmc.tv and give them your order number and a link to this thread.
I will do so. Thank you for the prompt reply!
Yes send an email through and we will get back to you shortly
Hi Sam,
Not sure what is going wrong, but I don’t get any response on my emails since last Friday. Can you please check? I have done the additional tests you requested, but nothing works unfortunately, So can you please provide me with a solution?
At this moment the Vero V is broken in the box for a week already after two weeks of usage. This is my eight OSMC device and I really like the OSMC platform, so I hope a solution is on the horizon soon.
Regards, Olaf.
I am up to date on emails from Monday. Please re-send. But I will have a few days of backlog which I will be up to date on by Saturday evening latest.
The 4K/4K+ deprecation caused a lot of orders and queries about the new flagship. As I am also travelling this caused some delays.
Will pick it up shortly
Thank you for the prompt reply. I will sent you another email.
I’ve got your emails and will reply shortly.
I am up to date on all emails and sent you a reply earlier. I think you posted this after.
Will await your response by email. If you haven’t received anything do let me know here.
Hi Sam,
Yes you are correct I saw your email yesterday evening after my post, so missed your mail earlier. I tried to remove the post on the forum because of this, but this didn’t work apparently. Sorry for this. I am trying to make the restore working, but no success so far unfortunately. Will keep you posted by email.
