Vero V now selectable in Unifi Network Controller
Today I was installing a new Vero V and noticed that while the Unifi Network Controller does not autodetect that the Vero V is one, it is now a selectable type via “Change Icon”.
Woo hoo! I just updated mine. One less generic or wrong icon to look at. '-)
That’s cool!
I’m on an outdated controller version here. Does it show up when you select Change Icon or did you have to manually upload it?
Not sure who uploaded it. I remember discussing it with @darwindesign some time ago.
Unfortunately you’ll probably only see our branded MAC address for wired connections. We don’t directly produce a WiFi module at this time, so the MAC for that will show another vendor.
You click on the name/icon and it pops up the options to identify your device. If you search for Vero or OSMC it gives one option which is the Vero V one shown in the OP.
Wasn’t me. I’d forgotten all about it.
I am all wired so I don’t think they have added, successfully at least, whatever is needed for their fingerprinting to work.
Like @pkscout I am just happy to have “everything in order” :slight_smile:
