I’ve noticed a playback issue on my Vero V - which affects only old files, where SW decoder is used.
It’s either dropping frames or playing with wrong timing - in result playback is clearly not smooth.
For example old AVI files, SD resolution, decoder used ff-mpeg4 (SW)
CPU usage is normal - usually max 15% on each core
and I remember that when I got Vero V it was fine (same on my old Vero 4k) - so it must me something in one of the updates
I don’t play files like that often - so I don’t know when it started
any ideas how to solve it? or how to diagnose it to report it properly?
I could only get rid of the frame skipping by whitelisting 576p/50 but that introduces other problems concerning the aspect ratio and i assume also with higher resolution content at the same refresh rate
tried all 3 builds available through the installer
Media Info is reporting 122Mb/s as the bitrate for that SD MPEG2 video - that can’t be right can it?
(DVD Video maxes out at below 10Mb/s - and broadcast quality 4:2:2 I-Frame only IMX50/D10 is only 50Mb/s)
Could just be a file authoring funny and not relevant of course. How big is the file and how long?
Also is it “Musikvideos/Genesis/The Video Show/VIDEO_TS” that you are having issues playing? (It looks like the log is for replay of more than one clip)
That is the DVD that i played. I took the VTS_01_1.VOB as a sample for mediainfo, the file is 1GB and around 20min long.
I noticed that if i play the file directly the hw-decoder is used but not if i play the same section using VIDEO_TS.IFO. I probably will not investigate this further as i figured that the mpeg2 hw-decoder has problems with playing some DVDs anyways.
That fixed aspect ratio problems with 4/3 DVDs but also let 16/9 DVDs play as 4/3.
