Hi, over the last few days, the power supply of my Vero V has been getting very warm to hot. I’ve now noticed that this apparently faulty PSU was causing an interference noise through the speakers connected to my AV receiver. The noise was audible as long as the PSU was plugged in and disappeared when unplugged. Setup: Vero V → HDMI → AV receiver → speakers. I’m currently using a replacement power supply, and both the overheating and the interference noise have completely disappeared.
Has anyone else experienced this with the original Vero V PSU? Is this a known issue indicating a faulty unit?
Plugged directly into the wall with enough space between it and other plugs. I'm currently using a different power supply. No more overheating. No more interference. The original power supply is simply "am Arsch".
That was a rather blunt way of putting it. It means the power supply is broken. I've already described the signs above. I'd gladly accept an offer for a new one. I posted this to inform you about this strange technical issue.
