I’m currently using a 2017 Nvidia Shield and considering the Vero V, primarily for its Dolby Vision FEL support.
For those who own one, how has your experience been with its overall stability and A/V reliability? How well does it handle Dolby Vision playback in practice?
Also, is there a reliable Plex add-on for Kodi that works well for remote streaming?
Is there anything else I should know or consider before pulling the trigger?
Stable as a rock, plays all I have and I use a Plex add-on, though that one isn’t supported, so if you get issues with it, too bad. Though have been using it for five years now, but after a major update, it might break and you will have issues with it.
That’s the only thing making me hold back about telling OP to just buy it.
We are here and we can support you a lot better than NVIDIA can and care about. BUT, and it’s a big but, we don’t have anything to do with Plex or its add-ons.
Yeah, I know you guys have nothing to do with Plex or its add-ons. I was just asking generally in case anyone here happens to use Plex as a Kodi add-on. It’s a minor consideration for me, since I occasionally use Plex for remote playback, but the vast majority of the time, I use Kodi for local playback. I suppose I could always keep using my Shield for remote playback if I can’t get a Plex add-on working to my satisfaction.
So just to confirm, DV profiles 7 FEL/MEL, 8.1 and 5 all work?
Dude, your dev team has the author of one of the main Plex add-on in it.
Your well covered with Plex right now. I haven’t updated it in a bit but I think the only thing that has changed since I wrote this up is the old regular Plex add-on got retired and the Plexmod one finally made it to Kodi’s repo…
For the vast majority of users the OSMC remote works well for the users. The first release Vero V’s did suffer from a higher instance of problems in some situations with RF interference but the receiver has since been updated to address that problem. Also, it is worth keeping in mind that this is primarily a support site so you are going to see a lot more posts about people posting issues than you would see elsewhere on the interwebs. It is easy to get a skewed perspective on a support site.
Additionally, the Vero is not locked into using just the remote it came with. It has an IR sensor that can be used with universal remotes, bluetooth, CEC, web interface, Kodi apps, and other options can be plugged in via USB.
