Vero V remote has stopped working
Hello all,
my Vero V remote has stopped working.
The light on the remote is coming on when I press buttons, and I’ve checked the battery is good (a touch over 3V on the multimeter).
I have rebooted, checked for updates (I’m on the latest), and tried to re-pair. When I try and re-pair the light on the remote stays on for a bit then just goes out.
The remote for the AV receiver will control the Vero just fine, as will a separate OSMC remote I bought a few years back (when I plug the dongle in the side of the Vero).
Logs are here for your perusal: https://paste.osmc.tv/rotediyuve
Thanks in advance for the help!
I suggest contacting support@osmc.tv.
Thanks Sam, have just done so.
Sam,
not heard back from you on this since I replied back with my order number as requested.
I am still about 60 tickets behind, but working through them diligently.
Can you let me know your ticket # so I can check the status?
Do apologise for delays
Sam,
that’s really appreciated, thank you.
the ticket number is #531210.
Cheers.
Sam, please remind our ticket #351491 (remote not pairing out of the box) , thx U
Sorry. If you reply via MyOSMC.com it does not bump the ticket priority, so it can stay as resolved.
For faster responses, please reply via email in the future for a more expedient response. Otherwise it takes a couple of more days.
Sam,
finally got around to this!
New external dongle plugged into the USN 2 port, paired with remote, and all working as it should.
Thanks so much for the help, appreciated!
Most welcome. Glad this is resolved for you.
