Vero V remote stopped working
Hello,
I’ve just received my new unit, connected temporarily to a monitor, configured some things and turned off (by software and then unplugged).
After dinner, I’ve turned it on but the remote is completely unresponsive.
Already tried to press home+ok for 5 seconds but nothing happens. I cannot use yatse on my phone because I cannot press ok after the warning about not exposing on internet.
the blue led on the remote works
How can I solve?
Do you have any USB devices connected to the device?
Have you tried restarting the device?
Can you attach a keyboard temporarily to control the device? We can then get a log and check what the problem is with the remote.
Hello Sam,
Thank you for your very fast reply.
No.
I’ve red about some remote issue regarded to usb 3 devices
Yes, twice but without success.
I’ve also tried to swap the remote’s battery with a sealed one but it didn’t work
Yes, I can. I should have some emergency usb keyboards.
Can you tell me what to do?
Bye
  • upload the log set (all configs and logs!) either using the Log Uploader method within the My OSMC add-onI or the ssh method invoking the command grab-logs -A
Hello,
I followed the tips on the support request page and here is my log:
https://paste.osmc.tv/edaxujusij
Have a look here:
2023-11-18 08:55:01.971 T:2747 debug : CEGLNativeTypeAmlogic::StopMonitorHWEvent – stopping event monitor for HDMI hotplug events
2023-11-18 08:55:02.076 T:2889 debug : Thread libinput 4004503808 terminating
2023-11-18 08:55:02.752 T:2912 debug : Thread FDEventMonitor 3912229120 terminating
2023-11-18 08:55:02.753 T:2878 debug : Thread Lirc 4023382272 terminating
2023-11-18 08:55:02.754 T:2877 debug : Thread Announce 4033433856 terminating
2023-11-18 08:55:02.754 T:2747 info : Exiting the application…
For some reason the HDMI hotplug in the monitor killed Lirc
Plugged on the TV, The remote works.
Do you have a explanation?
The remote doesn’t use or go through the LIRC subsystem. Nor is the remote controlled by Kodi and would work independently of this.
All your log shows is that you exited Kodi, and multiple threads stopped in that process.
This is expected behaviour
But the kodi interface was still there, Sam. I didn’t exit
Logs show that you stopped Kodi.
Are you still experiencing a problem?
Really, after connecting the vero to my A/V system, no.
So, I think that we can close the thread, at the moment
Thank you for the support
Let’s keep an eye on things
