Dear Sam
No you deform mainly what I said, to be clear for all readers and towards you
- True : I wrote this email with a bit of amertume
- False : I never said the Vero 5 used the same disspipator than 4K/4K+. I said that it suffers of overheating. This is totally different. How i can say that ?
- I spent 50% of the life of my vero 4K+ with a a saucepan (and not a bin, sorry for my english), put over it to cool it.
- Problems started when I massively migrated from h.264 to h.265 which is more ‘Soc’ Intensive
- Heat problems were FULLY solved with my self made heat sink (made of a true heat sink with fins and a 50mm blower, set @ 4.3V)
SO, I highly suspect Vero 5 has the same problem but as an evidence, to return it to you I did not open it. I would be pleased to, but it would void warranty. In fact I would be also very please so we get picture of the cooling system and not commercial outsides.
Why ? Because I never saw and in my life is long in this domain, such a poor dissipator on a SoC that emmit true heatness (case of Vero 4K+)
- There is a 5mm heatpad, this totally insane.
- The heatsink is a single aluminium plate, heatness can’t be disspated.
- 20% of the heatpad touch ‘nothing’ beacuse in contact with the support screw
This has to be known
From the short tests I did with Vero V playing high bitrate h.265 (>100Mbps) and AV1 files, the SoC heats a lot from 80°C to 90°C, that’s too my mind too much. Also it did not play flawlessly 192 khz 24b audio track. From all the devices I own, SHIELD is the only one to do it properly.
I did reports (may be multi login) by the past and did read many posts realtive to 4K+ problems. What I’ve learnt is : Do it yourself as such devloppement is in constant evolution and will never be as rock stable as an UNIX distribution.
By the end I fully appreciate your move and considering my problem with accepting my return. I did bought by past 4K and 4K+ because you are/were really serious.
I was hopping much from Vero 5, and sadly it is much below from my expectation.
- It agonizes getting a fluent GUI 4K/60 fps and high resolution posters.
The bundle will be returned with 2 hours used contition. The case is absolutely unopened, and I also added your genuine Vero 4K+ HDMI cable complementary to Vero 5 HDMI cable that has been unrolled. I can’t do better. Everything else is in brand new conditions.
Indeed I return it to you at my fees wihin 28 days starting reception with “change my mind on the product” conditions terms.
I know my video players environnements may be not like all others. My minimals t° are something like 27°C minimals up to 40°C, hardware need extra cooling, even my AVC has extra cooling, so I don’t flame OSMC. I am just questioning about some points, and decided to not follow the adventure with you anymore, that’s all.
I did build a RDNA 2 + 5600X + 3200CAS14 DDR4 + 2.5 GB LAN as main high end video player and it litteraly blows Vero V which has a dedicated hardware which is not the case of either my CPU or GPU.
My source is not shit USB drive or local drive, it is a RAID5 24TB server, with 20GB LAN, 640MBs drives throuputs. We can definitely exclude it from the equation.
(I’ve got better result over 2.5 Gbps LAN players than with 1 Gbps ones in all cases, did tried all buffer / cache combinations)
I lately test you vero V because of being perusaed that it will rocks, but to my mind / opinion, it does not.
I orientate my tests now to massively watercooled o/c Pi5, because SHIELD suffers of only one thing : fast forward/backard outside of chapters. It turned mad since Kodi 21.
As for now Android libraries performs better than x86/x64.
Do not know enough about ARM architecture / Kodi
So receive my best regards from a 10 years loyal customer.
