Hello everyone,
sorry, if the title is misleading, but i don´t know how to tell the phenomenon in a few words.
I am using the following setup:
- TV: Samsung 65" KU6079
- Soundbar: Teufel Cinebar 11
- Vero V (latest version of OSMC from May is installed) with connected USB-Drive 5,25"
- Fire TV Stick 4K
The connections are as following:
TV is connected to the soundbar via ARC-HDMI on both sides.
Fire TV is connected to the soundbar via the HDMI input of the soundbar.
Vero V is connected to the TV via HDMI 2 Port on the TV and via optical S/PDIF to the Soundbar.
It happens occasionally while watching movies via Fire TV that - without pressing a button - the Vero V is switching to active HDMI signal and showing the last used screen (no movie or other media playing). I can then switch back to other HDMI source (i.e. Fire TV), but sometimes only a few minutes later the same thing happens again. However, the behavior is not consciously reproducible and seems random.
I have tried to lookup for a setting on Vero V, which could trigger this behaviour, but i couldn´t find anything (or at least anything that could be possible for my understanding). I even looked on the TV menu, but there isn´t anything either, which could explain this to me.
Additionally - if i am watching movies on Vero V, there are no problems and the Fire TV doesn´t show the same behaviour and is not switching to active without pressing a button.
Is there anything i can check on the Vero V/ OSMC which could be a possible cause for switching to active signal sometimes?
Thanks in advance
Jogo
