Vero V to replace Mede8er player?
My Mede8er player has served me well for over 10 year now but I think it’s time for an upgrade. My requirements are fairly basic as I don’t stream at all. I need a player to be able to play H.264 and H.265. I have my files on a USB SSD drive and am used to accessing them in folders so don’t need any fancy interface. I want it to be able to remember the place in the video and to be able to turn off any subtitles which may be coded in a file.
I have looked at various specs and the Vero V seems to fit the brief.
I realise that on this forum you may be biased but is the Vero V a good option for me?
Thanks in advance.
Andyfr.
Playing from a USB drive is a very simple use case and should work just fine out of the box.
You could still do that with Vero V but you may want to spend some time understanding Kodi’s library system to get the full benefits of that on Vero.
Kodi maintains watched status for both files that have been scrapped into a library and ones that have not.
In addition to doing this via the player controls menu, the OSMC remotes have been programed such that you can long-press (hold down for ~1 second) the play button to toggle soft subtitles on/off, and long-press the stop button to bring up the subtitle settings screen where subtitle selection and other settings are found.
I would note that maintaining a library (scraping) isn’t only about a “fancy interface”. If you maintain any sort of permanent collection of videos a library allows widgets to work so you can have on your home page lists such as in-progress movies, series, and music, as well as recently added for each. You can also do things like hide watched items (movies or episodes) and have series automatically navigate a series into the first unplayed episode. It is also not an all or nothing proposition. I keep a folder that isn’t scrapped into my library for things I plan on deleting after watching and it works well avoiding extra maintenance on the library.
Thanks for the replies guys. It looks like the library interface might be a good option to have.
It’s very simple to set up, but might involve restructing your files a bit. See https://kodi.wiki/view/Video_library.
Thank you all. I have just ordered one!
It will ship on Tuesday. Tomorrow is a Bank Holiday in the UK.
Thanks Sam. I’m in the UK too so I expected that the order wouldn’t be processed until Tuesday at the earliest. Looking forward to it.
