Hi. I’m running OSMC on a Pi 3 and looking at a well-overdue upgrade to 4K. So considering Pi 5 or the Vero V. I see that functionally the Vero does everything a Pi does and more and better, but I’m concerned that it has been made a “Consumer product” rather than a project and I won’t be able to dabble with it so much (Vero may say “break it”). Is this a concern or can I do everything I can with a Pi? If the answer is “Yes, it does everything but better” then no need to read on. Otherwise, my specific concerns are:
- My library is on NAS with a mySQL database. Can I still edit the kodi config files (eg advancedsettings.xml) using SSH from my laptop?
- Can I use my Kodi Remote on phone or iPad? For music I don’t have the TV on (just Pi and Amp) so cannot use the on-screen UI and use the phone Remote App instead. Its far easier even with the TV on! The App requires a static IP for the Pi (or else have to keep adding a new Host). Which is the next question…
- Can I configure the network settings to have a static IP? I do this on my Pi as part of the SD Card installation process, but on a Vero it will be pre-installed so that opportunity is lost. Not aware if it is changeable thereafter.
- Can you change Skins? And use Add-ons? My favourite Artists Slideshow add-on requires it to be enabled in the skin (and the default OSMC skin does not).
Thanks in advance!
Mic
