Just a quick question:
I have a Vero 4K starting to go sluggish and I’m considering upgrading to Vero V. Is it easy to switch?
My greatest fears are the harmony hub - as I remember struggling setting this up, and tvheadend.
Since I’m a new dad, my time to poke around for a solution can run dry quickly…
Congrats on being a new dad
Can’t say for the Vero V, as it is at our summer residence.
But, the Vero V is practically using the same as the Vero 4K+, hence I suspect it should work fine.
PS: Vero 4 getting sluggish is usually a DB or other issue. Maybe you want to check what is happening inside? Check the process table/run “top” to see which process is using up resources.
