Vero V > What vpn's currently work with
HI Community … recently purchased the Vero V and subscribe to NordVPN. I also recently learned that Nord does not support the current version (caught up to ) of Python on the Vero V. I am not a coder so I ask the simple question of what VPN service currently pairs up with the latest version of OSMC.
NordVPN should work just fine if it still supports the OpenVPN protocol.
Pretty much any VPN provider should support this.
HI Sam … As stated previously Nord itself told me that it is currently incompatible. Without being partial any vendors that can be recommended? Thanks in advance …
NordVPN provide OpenVPN files here: OpenVPN configuration files | NordVPN, so it would work just fine on OSMC. There are users using NordVPN just fine on this forum — Python version is irrelevant.
Thanks Sam. I was just passing what they told me. I will give it a try. Thanks for the time and support.
I’ve got NordVPN running on a Vero 4k+ with the latest image. Been using it for over 3 years some without problems.
Explained the setup and install instructions here : [HowTo] Permanent NordVPN tunnel on OSMC - #40 by alphaque
Hope this helps.
