Dear friends,
Vero2 running as received.
As the CEC is still breaking after going on standby I tried to see if there is an update and tried to look for it manually but I get a red cross error message down bottom right corner saying update plugin failed and too see the logs.
Here are the logs. Thanks for any help.
http://paste.osmc.io/suyeciyoxu
libCEC will arrive next Sunday for Vero 2 and will greatly improve CEC.
I’m not quite sure of your question though
Your log file shows that the MyOSMC service has stopped running, which will require a reboot to start working again. Until rebooted checking for updates will fail.
Also your log file is absolutely massive apparently due to a problem reading the EDID from your TV, so check your HDMI cable is in securely, do a reboot, then try checking for updates again.
If it fails again post your logs again immediately after the failure.
