Is the Vero4K+ supposed to work with the Fritz USB WLAN AC860 Stick? If i put the stick in, the sticks LED is lighted, but after several seconds the light goes of…
And how can I see what wlan hardware is used for my network connection?
Vero 4k + comes with integrated wlan
but is it fast enough for 4K files?
Well, yes. Why do you suspect it wouldn’t be?
had a lot of playback freezes with. 4k files while playing them over wöan from my nas (nfs share)
what kind of wlan chipset is build into the vero4k+?
802.11ac AP6255 (433Mbps). It is SDIO integrated; so there is no congestion with USB.
ok, but shouldnt the fritz 866mb stick work with the vero too?
I don’t know. A log will show us if it’s being detected
