CalcFrameRate framerate was:25.000000 calculated:50.000000
I’m having an issue with certain files suddenly playing back through plexkodiconnect at double the refresh rate after updating to kodi 19.3 on a Vero 4K+. I’ve verified that framerate doubling is off and have both enabled and disabled the whitelist as well. It seems to happen with 25hz content, but I also have a musical concert that played back fine before the update that is running at 29.97hz that also has the doubling issue. I’m not sure if it’s the files themselves, but they played back perfectly before on kodi 19.1/19.2.
2021-12-05 05:59:05.812 T:2675 DEBUG <general>: ------ Window Init (VideoFullScreen.xml) ------
2021-12-05 05:59:05.812 T:2725 DEBUG <general>: PLEX.kodimonitor: Method: Player.OnAVChange Data: {'item': {'id': 14375, 'type': 'episode'}, 'player': {'playerid': 1, 'speed': 1}}
2021-12-05 05:59:05.816 T:2675 INFO <general>: [WHITELIST] Searching the whitelist for: width: 1920, height: 1080, fps: 25.000, 3D: false
2021-12-05 05:59:05.817 T:2675 DEBUG <general>: [WHITELIST] Searching for an exact resolution with an exact refresh rate
2021-12-05 05:59:05.818 T:2675 DEBUG <general>: [WHITELIST] Matched an exact resolution with an exact refresh rate 1920x1080 @ 25.00 - Full Screen (24)
2021-12-05 05:59:05.819 T:2675 INFO <general>: Display resolution ADJUST : 1920x1080 @ 25.00 - Full Screen (24) (weight: 0.000)
2021-12-05 05:59:05.822 T:29260 DEBUG <general>: OnAVChange: CApplication::OnAVChange
2021-12-05 05:59:05.853 T:2675 DEBUG <general>: ------ Window Deinit (DialogBusy.xml) ------
2021-12-05 05:59:05.893 T:2694 DEBUG <general>: ActiveAE::SyncStream - average error of 1000.473176, start adjusting
2021-12-05 05:59:05.915 T:2725 DEBUG <general>: PLEX.kodimonitor: Method: Player.OnAVStart Data: {'item': {'id': 14375, 'type': 'episode'}, 'player': {'playerid': 1, 'speed': 1}}
2021-12-05 05:59:05.916 T:2725 DEBUG <general>: PLEX.kodimonitor: Method: Player.OnAVChange Data: {'item': {'id': 14375, 'type': 'episode'}, 'player': {'playerid': 1, 'speed': 1}}
2021-12-05 05:59:06.842 T:2694 DEBUG <general>: ActiveAE::SyncStream - average error 19.073208, last average error: 1000.473176
2021-12-05 05:59:06.973 T:2694 DEBUG <general>: ActiveAE::SyncStream - average error of 7.499598, start adjusting
2021-12-05 05:59:06.973 T:2694 DEBUG <general>: ActiveAE::SyncStream - average error 0.499598 below threshold of 30.000000
2021-12-05 05:59:07.441 T:2794 DEBUG <general>: PLEX.subscribers: Sent server notification with parameters: {'X-Plex-Client-Identifier': '59b4982b-70e4-4e21-9b24-fcbf8eabab47', 'X-Plex-Device': 'Linux', 'X-Plex-Device-Name': 'osmc', 'X-Plex-Model': '4.9.113-55-osmc', 'X-Plex-Platform': 'Generic', 'X-Plex-Platform-Version': '1.0.0', 'X-Plex-Product': 'PlexKodiConnect', 'X-Plex-Version': '3.5.8', 'state': 'playing', 'ratingKey': 71631, 'key': '/library/metadata/71631', 'time': 95321, 'duration': 2824672, 'playQueueItemID': 117441, 'X-Plex-Token': 'rSEfbT4CD-LCTogG9E3Q'} to https://192-168-1-180.e3aabca1bfcb4e789801912d7bc6ff78.plex.direct:32400/:/timeline
2021-12-05 05:59:07.917 T:2725 DEBUG <general>: PLEX.playlist_func: The PMS wants to display video stream with Plex id 401620 and languageTag None
2021-12-05 05:59:07.919 T:2725 DEBUG <general>: PLEX.playlist_func: Switching to Kodi video stream number 0 because the PMS told us to show stream with Plex id 401620
2021-12-05 05:59:07.920 T:2725 DEBUG <general>: PLEX.playlist_func: Not switching video stream (no change)
2021-12-05 05:59:07.923 T:2725 DEBUG <CAddonSettings[plugin.video.plexkodiconnect]>: trying to load setting definitions from old format...
2021-12-05 05:59:07.935 T:2725 DEBUG <general>: PLEX.playlist_func: The PMS wants to display audio stream with Plex id 401621 and languageTag en
2021-12-05 05:59:07.935 T:2725 DEBUG <general>: PLEX.playlist_func: Switching to Kodi audio stream number 0 because the PMS told us to show stream with Plex id 401621
2021-12-05 05:59:07.938 T:2725 DEBUG <general>: PLEX.playlist_func: Not switching audio stream (no change)
2021-12-05 05:59:07.941 T:2725 DEBUG <CAddonSettings[plugin.video.plexkodiconnect]>: trying to load setting definitions from old format...
2021-12-05 05:59:07.951 T:2725 DEBUG <general>: PLEX.playlist_func: Deactivating Kodi subtitles because the PMS told us to not show any subtitles
2021-12-05 05:59:07.955 T:2725 DEBUG <general>: PLEX.playlist_func: The PMS wants to display video stream with Plex id 401620 and languageTag None
2021-12-05 05:59:07.955 T:2725 DEBUG <general>: PLEX.playlist_func: Switching to Kodi video stream number 0 because the PMS told us to show stream with Plex id 401620
2021-12-05 05:59:07.957 T:2725 DEBUG <general>: PLEX.playlist_func: Not switching video stream (no change)
2021-12-05 05:59:07.961 T:2725 DEBUG <CAddonSettings[plugin.video.plexkodiconnect]>: trying to load setting definitions from old format...
2021-12-05 05:59:07.973 T:2725 DEBUG <general>: PLEX.playlist_func: The PMS wants to display audio stream with Plex id 401621 and languageTag en
2021-12-05 05:59:07.974 T:2725 DEBUG <general>: PLEX.playlist_func: Switching to Kodi audio stream number 0 because the PMS told us to show stream with Plex id 401621
2021-12-05 05:59:07.976 T:2725 DEBUG <general>: PLEX.playlist_func: Not switching audio stream (no change)
2021-12-05 05:59:07.980 T:2725 DEBUG <CAddonSettings[plugin.video.plexkodiconnect]>: trying to load setting definitions from old format...
2021-12-05 05:59:07.994 T:2725 DEBUG <general>: PLEX.playlist_func: Deactivating Kodi subtitles because the PMS told us to not show any subtitles
2021-12-05 05:59:07.997 T:2725 DEBUG <general>: PLEX.playlist_func: The PMS wants to display video stream with Plex id 401620 and languageTag None
2021-12-05 05:59:07.997 T:2725 DEBUG <general>: PLEX.playlist_func: Switching to Kodi video stream number 0 because the PMS told us to show stream with Plex id 401620
2021-12-05 05:59:07.999 T:2725 DEBUG <general>: PLEX.playlist_func: Not switching video stream (no change)
2021-12-05 05:59:08.003 T:2725 DEBUG <CAddonSettings[plugin.video.plexkodiconnect]>: trying to load setting definitions from old format...
2021-12-05 05:59:08.014 T:2725 DEBUG <general>: PLEX.playlist_func: The PMS wants to display audio stream with Plex id 401621 and languageTag en
2021-12-05 05:59:08.015 T:2725 DEBUG <general>: PLEX.playlist_func: Switching to Kodi audio stream number 0 because the PMS told us to show stream with Plex id 401621
2021-12-05 05:59:08.017 T:2725 DEBUG <general>: PLEX.playlist_func: Not switching audio stream (no change)
2021-12-05 05:59:08.020 T:2725 DEBUG <CAddonSettings[plugin.video.plexkodiconnect]>: trying to load setting definitions from old format...
2021-12-05 05:59:08.031 T:2725 DEBUG <general>: PLEX.playlist_func: Deactivating Kodi subtitles because the PMS told us to not show any subtitles
2021-12-05 05:59:08.035 T:2725 DEBUG <general>: PLEX.playlist_func: The PMS wants to display video stream with Plex id 401620 and languageTag None
2021-12-05 05:59:08.035 T:2725 DEBUG <general>: PLEX.playlist_func: Switching to Kodi video stream number 0 because the PMS told us to show stream with Plex id 401620
2021-12-05 05:59:08.036 T:2725 DEBUG <general>: PLEX.playlist_func: Not switching video stream (no change)
2021-12-05 05:59:08.040 T:2725 DEBUG <CAddonSettings[plugin.video.plexkodiconnect]>: trying to load setting definitions from old format...
2021-12-05 05:59:08.050 T:2725 DEBUG <general>: PLEX.playlist_func: The PMS wants to display audio stream with Plex id 401621 and languageTag en
2021-12-05 05:59:08.051 T:2725 DEBUG <general>: PLEX.playlist_func: Switching to Kodi audio stream number 0 because the PMS told us to show stream with Plex id 401621
2021-12-05 05:59:08.053 T:2725 DEBUG <general>: PLEX.playlist_func: Not switching audio stream (no change)
2021-12-05 05:59:08.056 T:2725 DEBUG <CAddonSettings[plugin.video.plexkodiconnect]>: trying to load setting definitions from old format...
2021-12-05 05:59:08.068 T:2725 DEBUG <general>: PLEX.playlist_func: Deactivating Kodi subtitles because the PMS told us to not show any subtitles
2021-12-05 05:59:08.239 T:29288 DEBUG <general>: CPtsTracker: detected pattern of length 1: 20000.00, frameduration: 20000.000000
2021-12-05 05:59:09.079 T:2794 DEBUG <general>: PLEX.subscribers: Sent server notification with parameters: {'X-Plex-Client-Identifier': '59b4982b-70e4-4e21-9b24-fcbf8eabab47', 'X-Plex-Device': 'Linux', 'X-Plex-Device-Name': 'osmc', 'X-Plex-Model': '4.9.113-55-osmc', 'X-Plex-Platform': 'Generic', 'X-Plex-Platform-Version': '1.0.0', 'X-Plex-Product': 'PlexKodiConnect', 'X-Plex-Version': '3.5.8', 'state': 'playing', 'ratingKey': 71631, 'key': '/library/metadata/71631', 'time': 96964, 'duration': 2824672, 'playQueueItemID': 117441, 'X-Plex-Token': 'rSEfbT4CD-LCTogG9E3Q'} to https://192-168-1-180.e3aabca1bfcb4e789801912d7bc6ff78.plex.direct:32400/:/timeline
2021-12-05 05:59:09.457 T:2728 DEBUG <CAddonSettings[service.upnext]>: trying to load setting definitions from old format...
2021-12-05 05:59:09.761 T:29288 DEBUG <general>: Skipped 2 duplicate messages..
2021-12-05 05:59:09.761 T:29288 DEBUG <general>: CalcFrameRate framerate was:25.000000 calculated:50.000000
2021-12-05 05:59:09.799 T:29288 DEBUG <general>: CRenderManager::Configure - change configuration. 1920x1080. display: 1920x1080. framerate: 50.00.
2021-12-05 05:59:09.815 T:2675 DEBUG <general>: DeleteRenderer - deleting renderer
2021-12-05 05:59:09.815 T:2675 INFO <general>: Constructing CRendererAML
2021-12-05 05:59:09.816 T:2675 DEBUG <general>: CRenderManager::Configure - 8
2021-12-05 05:59:09.823 T:29259 DEBUG <general>: OnAVChange: CApplication::OnAVChange
2021-12-05 05:59:09.848 T:2675 INFO <general>: [WHITELIST] Searching the whitelist for: width: 1920, height: 1080, fps: 50.000, 3D: false
2021-12-05 05:59:09.848 T:2675 DEBUG <general>: [WHITELIST] Searching for an exact resolution with an exact refresh rate
2021-12-05 05:59:09.849 T:2675 DEBUG <general>: [WHITELIST] Matched an exact resolution with an exact refresh rate 1920x1080 @ 50.00 - Full Screen (28)
2021-12-05 05:59:09.850 T:2675 INFO <general>: Display resolution ADJUST : 1920x1080 @ 50.00 - Full Screen (28) (weight: 0.000)
