Vero4K Constantly rebooting
So my Vero4K started acting up…slow response, rebooting etc.
The only error in the log was an entry about not locating /dev/input/event1-5 files. Even though they are present with proper rights. Exactly the same as my Vero4K+…which is working fine.
I tried a reinstall from a USB key twice, but now it reboots right at the initial OSMC skin page. Not enough time to ssh in or gather logs.
And now it will not even boot from the USB thumbdrive, goes directly to the OSMC opening page then reboots.
Is this EOL for a 2018 Vero4K
Have you tried using the power supply from the working V4k+?
SOLVED
I eventually got to replacing the PS…fortunately I had a couple new 5V/2A spares from when it failed a couple years ago.
It was the power supply causing the issues once again.
I was not expecting the USB boot drive to be erased once the image was transferred.
By the 3rd reboot I checked the USB drive and realized it can only be run once. :neutral_face:
For protecting people from being stuck in reinstall circle
