Had my vero for a few years now, great little device.
I always have used it wired, however I recently moved so for the time being I enabled wifi.
When I went to enable wifi the device crashes with the
emoji on the screen.
I power cycle and reboot and when I disable wifi the same thing happens.
After the crash the device can not fetch media info at all, I can browse the network but it seems that everything external to my network stops working.
Not until I reset the kodi database is when things start working again.
I’m using 3D BR ISOs served up from my network, and for other content I use EMBy Next Gen plugin.
I am on the latest update.
After the crash the ISOs can not scrape anything from MovieDB and EMBY will not update content either.
This is not the case for anything wired.
