Hello
when I play DTS HD MA or TRUE HD MKV from my Synology, I have max 48KHZ and it should be 96 -192KHZ.
I have set to best match. If I set it to fixed, it goes to a maximum of 192khz but only PCM.
greez Mirko
Hello
greez Mirko
Where do you see this number? If you are using passthrough your AVR should indicate ‘TrueHD’ or ‘DTS-MA’ and you will be getting the best quality.
but i only see 48khz in the display of my anthem avr hd ma and it should be 96 or 192
Can you show us the mediainfo output (txt) of the video from here: MediaInfoOnline - MediaInfo in your browser
You can black out the file name if you want.
I think the files only have 48KHZ
General
Unique ID : 230018327278306581983656516339580559001 (0xAD0BEB1DFCAC6EFB4232C3860E0C5E99)
Complete name : xxxxx
Format : Matroska
Format version : Version 4
File size : 74.2 GiB
Duration : 2 h 56 min
Overall bit rate : 60.3 Mb/s
Movie name : xxxx
Encoded date : UTC 2022-05-16 22:35:53
Writing application : mkvmerge v66.0.0 (‘Josie’) 64-bit
Writing library : libebml v1.4.2 + libmatroska v1.6.4
Video
ID in the original source medium : 4113 (0x1011)
Format : HEVC
Format profile : Main 10@L5.1@High
HDR format : Dolby Vision, Version 1.0, dvhe.07.06, BL+EL+RPU, Blu-ray compatible / SMPTE ST 2086, HDR10 compatible
Codec ID : V_MPEGH/ISO/HEVC
Bit rate : 53.1 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Color space : YUV
Chroma subsampling : 4:2:0 (Type 2)
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.267
Stream size : 65.4 GiB (88%)
Title : xxx
Language : German
Default : Yes
Forced : No
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Matrix coefficients : BT.2020 non-constant
Mastering display color primaries : Display P3
Mastering display luminance : min: 0.0001 cd/m2, max: 1000 cd/m2
Maximum Content Light Level : 413 cd/m2
Maximum Frame-Average Light Level : 65 cd/m2
Original source medium : Blu-ray
Audio #1
Format : MLP FBA 16-ch
Format/Info : Meridian Lossless Packing FBA with 16-channel presentation
Commercial name : Dolby TrueHD with Dolby Atmos
Codec ID : A_TRUEHD
Bit rate mode : Variable
Bit rate : 3 064 kb/s
Maximum bit rate : 5 337 kb/s
Channel(s) : 8 channels
Channel layout : L R C LFE Ls Rs Lb Rb
Sampling rate : 48.0 kHz
Frame rate : 1 200.000 FPS (40 SPF)
Compression mode : Lossless
Stream size : 3.77 GiB (5%)
Title : German TrueHD Atmos 7.1
Language : German
Default : Yes
Forced : No
Number of dynamic objects : 11
Bed channel count : 1 channel
Bed channel configuration : LFE
Audio #2
Format : AC-3
Format/Info : Audio Coding 3
Commercial name : Dolby Digital
Format settings : Dolby Surround EX
Codec ID : A_AC3
Bit rate mode : Constant
Bit rate : 448 kb/s
Channel(s) : 6 channels
Compression mode : Lossy
Stream size : 565 MiB (1%)
Title : German AC3 5.1-EX
Language : German
Service kind : Complete Main
Default : Yes
Forced : No
Audio #3
Codec ID : A_TRUEHD
Bit rate : 3 028 kb/s
Maximum bit rate : 5 271 kb/s
Stream size : 3.73 GiB (5%)
Title : English TrueHD Atmos 7.1
Language : English
Default : Yes
Forced : No
Audio #4
Format : AC-3
Codec ID : A_AC3
Bit rate : 448 kb/s
Title : English AC3 5.1-EX
Language : English
Default : Yes
Forced : No
Text #1
Format : PGS
Codec ID : S_HDMV/PGS
Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs
Duration : 1 h 47 min
Bit rate : 750 b/s
Frame rate : 0.010 FPS
Count of elements : 62
Stream size : 589 KiB (0%)
Title : German Forced
Language : German
Default : Yes
Forced : No
Text #2
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Bit rate : 0 b/s
Frame rate : 0.005 FPS
Count of elements : 31
Stream size : 792 Bytes (0%)
Language : German
Default : No
Forced : No
Text #3
Format : VobSub
Codec ID : S_VOBSUB
Codec ID/Info : Picture based subtitle format used on DVDs
Bit rate : 194 b/s
Stream size : 152 KiB (0%)
Language : German
Default : No
Forced : No
Text #4
Format : PGS
Duration : 2 h 55 min
Bit rate : 34.3 kb/s
Frame rate : 0.458 FPS
Count of elements : 4834
Stream size : 43.1 MiB (0%)
Title : English
Language : English
Default : No
Forced : No
Text #5
Format : VobSub
Codec ID : S_VOBSUB
Bit rate : 8 124 b/s
Frame rate : 0.229 FPS
Count of elements : 2416
Stream size : 10.2 MiB (0%)
Title : English
Language : English
Default : No
Forced : No
Text #6
Format : PGS
Bit rate : 35.2 kb/s
Frame rate : 0.353 FPS
Count of elements : 3728
Stream size : 44.3 MiB (0%)
Title : German
Language : German
Default : No
Forced : No
Text #7
Format : VobSub
Codec ID : S_VOBSUB
Bit rate : 8 437 b/s
Frame rate : 0.177 FPS
Count of elements : 1863
Stream size : 10.6 MiB (0%)
Title : German
Language : German
Default : No
Forced : No
Menu
00:00:00.000 : en:Chapter 1
00:12:01.429 : en:Chapter 2
00:23:21.692 : en:Chapter 3
00:31:53.870 : en:Chapter 4
00:41:44.544 : en:Chapter 5
00:51:36.719 : en:Chapter 6
01:00:12.943 : en:Chapter 7
01:10:32.437 : en:Chapter 8
01:18:35.169 : en:Chapter 9
01:29:14.766 : en:Chapter 10
01:42:33.189 : en:Chapter 11
01:52:16.939 : en:Chapter 12
01:58:21.261 : en:Chapter 13
02:09:40.022 : en:Chapter 14
02:21:14.508 : en:Chapter 15
02:27:31.384 : en:Chapter 16
02:38:36.173 : en:Chapter 17
02:46:58.133 : en:Chapter 18
Correct
Most lossless BD tracks have…
