As the title sais. At the moment I only know the “method” of pulling out/putting back in power socket. I tried pressing all the remote buttons… nothing. Sorry for the noob question.
Correct that is the only method to start the Vero4k after power down
The Vero4k is designed to run 24/7 and not to be shutdown. You can use the standby mode if you e.g. want the HDMI signal to be switched off.
Select Suspend instead of Shut Down
