Hey Sam, I hope praise in the Help and Support section is ok. After receiving my Vero4k+ yesterday, I was super excited to get it configured. It did take a very long time to ship and get here, but I’m really glad you had the order volume you did. This is am amazing product, and I want you to sell enough that you are able to continue your support. I already own a Vero4k device and a couple of Raspberry PI’s running OSMC.
My database is running on my Synology NAS in MariaDB 10. After copying over my advancedsettings.xml file and setting up my fstab cifs mounts and sources.xml file, pretty much everything seemed to work. I did tar up my Thumbnails directory and move it over as well.
I had an issue with my Samsung TV and HDMI-CEC on the Vero4k+. It was working on the Vero4k that I replaced, so I was scratching my head. Same version of OSMC, same version of the driver, etc. After an hour of head scratching, I unplugged power from my Samsung TV. After plugging it back in, HDMI-CEC worked just fine. I don’t have an explanation for what happened, but I’m happy it is working now.
For others on the fence about ordering the Vero4k+, I can provide some insight on why it’s worth it for me. I have quite a few UHD 4K videos. Almost all of them work just fine on the Vero4k. Two of the videos I had problems with. Both have very high bitrates. The highest one is reported as 85.9 Mb/s in MediaInfo, which should stream just fine on the Vero4k. It continued to stutter every so often, even though I was not chapter skipping. I simply could not get it play smoothly from end to end. Moving over to the Vero4k+, this issue is now resolved. Playing this video showed a peak bitrate of about 105 Mbps on my switch; again, no chapter skipping. I’m running a layer 3 managed switch from Ubiquiti, so it’s not network related.
The faster local flash memory is nice too, but the gigabit ethernet on the Vero4k+ is what I needed. I literally have nothing bad to say about it. I will be buying another soon. Here’s my setup for those interested.
After seeing some other posts here about network performance, I decided to run iperf3 like everyone else out of curiosity. I’m seeing very good network performance. Switch is a Ubiquiti (UniFi) EdgeMax 24 port gigabit layer 3 managed switch. Flow control is disabled, standard 1500 MTU.
For those with a Synology NAS that are looking to install iperf3 without lots of hassle, download the package that aligns with your DSM version and CPU chipset here: Synology DSM iPerf. The related thread is here: Synology Forum
