Bought an Vero4K in April and been using it occasionally. Last night wanted to use it (it was unplugged for a while), and now that I plug it in it doesn’t turn on. No red or blue light or sound, like it had no power at all. Tried with a different power supply and power outlet, but no luck any recommendation on what it might be? or any test that can be done?
Did you buy your Vero from someone second hand or from an unofficial seller or did you swap the power supply with one from an other device by accident?
The power supply I got with my 4k+ i bought from the store attatched to this forum looks like this :
That isn’t an official adapter. We don’t manufacture or sell this PSU anywhere, so you must have mixed it up with something else. Using this power supply would damage the device.
Dear Sam!
Thanks for the reply. I have looked thrgouh all the electronics and cables and found the proper adapter, it was mixed up with something else.
