A couple of hours ago I update my Vero4k to the latest OSMC.
I now audio issues when playing video (which I didn’t have before the update):
Audio initially plays fine. After a couple of minutes, short ‘gaps’ (silence) start, and the audio becomes more and more garbled and intermittent.
A couple of minutes later, audio goes back to normal sounding fine. Another couple of minutes later the intermittent silence and garbled sound reappear.
Any ideas? What info can I provide to help debug this problem?
reproduce the issue
When this is disabled, you will always have audio issues.
This won’t be new to this update. I suspect you may be playing new content and the older content wasn’t affected by this.
Well… it’s the first thing I tried after the update… since bluetooth was not working before, and I was hoping the update would fix it.
But bluetooth is disabled now (in MyOsmc) and still seeing the same problem.
All that I checked have the same problem… doesn’t seem related to a specific video.
I’ll be catching some sleep now, will check back here tomorrow.
Thanks!
There was no change to Bluetooth audio in this update.
But we actually are testing a different bluetooth audio approach which works well with several people.
I can give you the instructions if you want to test it.
But also when you don’t use Bluetooth currently I suggest you change the Audio Setting to HDMI (not Pulseaudio) in Settings.
Scavenging some other posts that appeared today, I have found the solution to my problem:
I also found the a2dp-app-osmc package on my Vero4k. I remember installing it a (long) while ago in an attempt to make my bluetooth headphones work properly.
After the update had a problem with audio passthrough ONLY with DD+( DD and DTS were passed along happily). Receiver was not recognizing the passthrough DD+ stream.
I had the same package installed.
Removing it and disabling bluetooth solved the problem for me as well.
