This week I upgraded my Vero4K to the latest June release. Once updated I noticed that I could no longer play nearly all of my videos. The video would start for a second but then immediately stop. If I retried a few times sometimes I could get the video to play. However quite a few of the videos just would never play. I went back to previously watched videos that were OK and these would also not play.
General Setup:
Vero 4K - Connected via Ethernet cable to Synology DSJ. Using an SMB network share. No previous problems using all images up until June release.
Things I’ve tried to fix it
- Reset Kodi from with OSMC - No change, still broken
- Reinstalled Vero4K image from June release - No change, still broken
- Reinstalled Vero4K image from March release - Works correctly with all media tested
Before I downgraded the OS image I took a log which shows the issue
https://paste.osmc.tv/docujufoze
The following extract I believe shows the issue:
DEBUG: Thread BackgroundLoader 3144676064 terminating
2020-09-27 17:00:25.460 T:3961696992 DEBUG: DoWork - took 309 ms to load special://skin/extras/backgrounds/1.jpg
2020-09-27 17:00:25.607 T:3132556000 INFO: CFileCache::Process - Source read didn't return any data! Hit eof(?)
2020-09-27 17:00:25.930 T:3680830176 DEBUG: Open - avformat_find_stream_info starting
2020-09-27 17:00:25.932 T:3132556000 ERROR: Read - Error( -1, 103, Software caused connection abort )
2020-09-27 17:00:25.932 T:3132556000 DEBUG: CFileCache::Process - Source read returned a fatal error! Will wait for buffer to empty.
2020-09-27 17:00:25.932 T:3132556000 DEBUG: Thread FileCache 3132556000 terminating
2020-09-27 17:00:25.933 T:3680830176 DEBUG: ffmpeg[DB6502E0]: [mov,mp4,m4a,3gp,3g2,mj2] Could not find codec parameters for stream 0 (Video: h264 (avc1 / 0x31637661), none, 720x400, 1090 kb/s): unspecified pixel format
Has anyone had anything similar? It looks like a network buffering or socket timeout issue of some kind but I have no idea of what settings to tweak.
I’m happy to try any changes or submit extra information etc.
