Log Files - https://paste.osmc.tv/zamohixica
I was having lag issues playing a file, so I began an investigation.
iPerf3 showed only 280Mbps downstream on my Vero4K with the recommended USB3 1Gbps Ethernet adapter from Realtek.
(I also have a Vero4K+ on the same switch…it performs at 932Mbps. I eliminated possible cabling issues and switch issues.) And I tried switching USB ports.
Dmesg shows some concerning errors such as
[ 2.563938] usb 1-1: New USB device found, idVendor=0bda, idProduct=8153
[ 2.563944] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=6
[ 2.563948] usb 1-1: Product: USB 10/100/1000 LAN
[ 2.563951] usb 1-1: Manufacturer: Realtek
[ 2.563954] usb 1-1: SerialNumber: 000001
[ 2.573339] usb 1-1: Unsupported device
[ 2.573607] usb 1-1: Unsupported device
and
[ 2.028922] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
[ 2.028976] usb usb2: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 2.029062] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 2.029067] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.029071] usb usb2: Product: xHCI Host Controller
[ 2.029074] usb usb2: Manufacturer: Linux 4.9.113-60-osmc xhci-hcd
[ 2.029078] usb usb2: SerialNumber: xhci-hcd.0.auto
[ 2.029509] hub 2-0:1.0: USB hub found
[ 2.029536] hub 2-0:1.0: config failed, hub doesn’t have any ports! (err -19)
[ 2.031380] usb usb2: Unsupported the hub
I could not find the Vero4K specs onsite, but I see the 4K+ specs show USB2 ports.
So now I cannot remember for sure what speeds I use to get on the Vero4K with the Ethernet Adapter
…also the OSMC log uploader would not work, so I went with grab-logs -A
