Vero4k red light, it won't boot
My Vero4k has always worked but this morning I noticed the red light at the front and after several power cycles it just doesn’t seem to boot.
Any ideas?
Could be a power supply issue. Do you have another Powersupply (5V, 2A center positive, 5.5mm OD; 2.1mm ID) that you could try? Alternatively you could also power the Vero with a USB (A-A) cable.
@fzinken, Yea didn’t give it much thought and pulled the triggered on the forum for help too quickly.
Tried a different power supply and the light went blue.
