I have a feeling the unit is on deaths door, not sure what else to try
It is showing continuous red light, the power supply works fine on another Vero4k and have tried a few other working power supplies and even USB power, but still just a red light.
Ethernet is also not working, and does not get a link light on the switch, have tried multiple ports and cables, I can get a connection by using a USB to ethernet adapter.
Could not get a response from the remote with a new battery, would not pair, used a dongle from my other Vero4K and it it worked with the remote.
I generated this log by booting up with just the ethernet plugged into the Vero4k’s port and the bad remote dongle plugged in, I don’t know if they will show anything on the logs, but thought it would be worth a shot. Once booted, I plugged in the USB to ethernet adapter and working remote dongle to be able to upload the logs
https://paste.osmc.tv/ucahijewoc
TL;DR background
This is my backup Vero4k that hasn’t been used in over a year, I recently reworked my media servers so I though it would be a good time to update the backup unit… but it booted to a cycling sad face, tried to install a new OSMC image from SD card and failed with a segmentation fault and then was stuck on a blank black screen.
I tried another install and was successful, but couldn’t get the remote to work until I switched the USB dongle, then couldn’t connect to the network during setup, I had a USB to ethernet adapter around so tried that and it worked for completing setup.
I tried another install of an image from Jan2020, but same issues. I had it do the system updates and during the blue screen updating parts the light was blue, but after the update went back to red
Strangely, while it is booting, it shows up as “mbox meson ref” on my receiver which my other Vero4k doesn’t do
