Vero4k remote problems
Hi there, I’ve had my vero4k for about 4 years and it’s never missed a beat but recently when I switch my vero on the remote never works for quite some time, it has a brand new battery in it and I’ve followed the instructions for pairing it again but still not working as it should.
Should I just buy a new remote? Thanks in advance for the help.
I’d suggest uploading some logs so we can check that the correct dongle is connected.
If you can upload some logs when the dongle is not working as expected this would be useful.
Are there any other devices connected?
Thank you for the quick reply and help, no other devices are connected to my vero, how do I get to the log so I can post it here.
Thanks again I’ve unloaded the log - https://paste.osmc.tv/oyapizeqiz
Have you tried the other USB port on the device?
I have tried both ports but I still have the same problem, after a fair bit of time when my vero4k has been on the remote will start to work.
Can you post a log when it does work?
I’ve reinstalled the latest software on my vero and it is still the same, what I have noticed is after an hour or so of it being on the remote will start working okay, I’ve just rebooted and it has stopped working, when it does start to work I will post an updated log.
Thank you very much for the help. :+1:
Here is the latest log with the remote working - https://paste.osmc.tv/tanefehabu
