All batteries were new (from a new pack)
The contact is good, I’ve taken a close look to be sure the contact is well done.
So i guess it might be a simple defect…
@sam_nazarko How could we handle the defect issue?
Last year I got a blister pack with 5 x CR2032 … and they were all dead! So, a volt meter could tell you the real condition.
You can contact support@osmc.tv
Will do
If the unit is out of warranty, you might want to unscrew the case and pop it off, I have noted that the battery connectors to the PCB have had dry joints on my old remote, a quick resolder and I fixed mine.
Regards,
Ed
