Problem is inside there are my OPENVPN Keys
Run grab-logs -A -C
, edit /boot/uploadlog.txt and then run paste-log /boot/uploadlog.txt
If you set settings>system>power savings>shutdown function>
to suspend instead of shutdown does this fix your issue?
The logs show that Kodi is receiving a shutdown signal and itβs exiting gracefully, i.e. not crashing.
https://paste.osmc.tv/bofozalugu
@darwindesign i will try this.
I changed it now to suspend.
Will give you a Feedback as soon as something happens
Thank you guys for all your effort!!!
Well that would mean that you must have configured some shutdown timer as this is how it normally looks
Check what you have configured under Energiesparen, here is the default settings
@darwindesign @fzinken seems like changing it to suspend was the right solution.
Thanks for helping
