Synchronizing state of autofs.service with SysV service script with /lib/systemd /systemd-sysv-install. Executing: /lib/systemd/systemd-sysv-install disable autofs insserv: warning: current start runlevel(s) (empty) of script 'autofs' overrides LSB defaults (2 3 4 5). insserv: warning: current stop runlevel(s) (0 1 2 3 4 5 6) of script 'autofs' overrides LSB defaults (0 1 6). insserv: warning: current start runlevel(s) (empty) of script 'autofs' overrides LSB defaults (2 3 4 5). insserv: warning: current stop runlevel(s) (0 1 2 3 4 5 6) of script 'autofs' overrides LSB defaults (0 1 6).
I just ignored it and went on to the reboot command, connection was lost and then when I reconnected I still couldn’t remove the directory. Trying the first command again gave me the same warnings listed above.
I attempted installing PVR software on the Vero a couple of days ago. Could it be locking up the directory?
Ok we can still remove the directory, but before we do; we need to make sure its still not providing access to the share. Please provide the output of:
sudo systemctl status autofs
mount|grep pvr (Please don’t be surprised if there is no output, this is to be expected.)
remove directory gave me failed to remove '/mnt/pvr': no such file or directory
Go figure.
enable autofs give us Synchronizing state of autofs.service with SysV service script with /lib/systemd/systemd-sysv-install. Executing: /lib/systemd/systemd-sysv-install enable autofs insserv: warning: current start runlevel(s) (empty) of script 'autofs' overrides LSB defaults (2 3 4 5). insserv: warning: current stop runlevel(s) (0 1 2 3 4 5 6) of script 'autofs' overrides LSB defaults (0 1 6).
Then I did sudo systemctl start autofs, hit enter and it just accepted the command and is waiting
My original plan was to have a PVR folder under the video folder. At some point I created a PVR folder parallel with the video folder.
During our conversation, I figured we were making headway with the video/PVR folder, so deleted the PVR folder that was parallel with the video folder. Now, the export list shows /volume2/video & /volume2/music and that’s it.
I quickly recreated that parallel PVR folder, restarted the Vero and now showmount only shows the two folder (video & music).
