My bad, not the output of installing the program but to run it against the new network connection (assuming it would be eth1 if you didn’t physically disabled the internal ethernet).
sudo ethtool eth1
sudo ethtool eth1
Settings for eth1:
Supported ports: [ TP MII ]
Supported link modes: 10baseT/Half 10baseT/Full
100baseT/Half 100baseT/Full
1000baseT/Half 1000baseT/Full
Supported pause frame use: No
Supports auto-negotiation: Yes
Advertised link modes: 10baseT/Half 10baseT/Full
1000baseT/Full
Advertised pause frame use: Symmetric Receive-only
Advertised auto-negotiation: Yes
Link partner advertised link modes: 10baseT/Half 10baseT/Full
Link partner advertised pause frame use: Symmetric Receive-only
Link partner advertised auto-negotiation: Yes
Speed: 1000Mb/s
Duplex: Full
Port: MII
PHYAD: 32
Transceiver: internal
Auto-negotiation: on
Link detected: yes
Ok looks good (btw I formatted your post using the </> button to make it easier to read.
Could you actually show us an iperf3 output for both directions Vero send and Vero receive.
ok, i’ll try…
If you unplug the WD drive, do the speeds go up?
Well, first of all, thank you all for yor great support! It makes your great products even better!
I was very busy installing the drives yesterday, just the way i wanted to.
I mounted them in the Kodi UI without any hassle and -surprise- there are no problems with the network speed at all!
Don’t know what the problem was with transfering files, but i’ve tested the performance watching “John Wick chapter 3” as UHD remux and there was no lag, no stuttering or anything!
I’m really happy with it now.
Thank you again!
