to increase the network speed on my vero4k i’ve bought the usb network adapter from csl that’s mentioned in many threads here.
Nowy network speed is lower than without the adapter, i used to have file transfers fromy pc to the vero with about 12MB/s, with the adapter the speed is 4- 7MB/s.
What am i doing wrong?
reboot the OSMC device
reproduce the issue
upload the log set either using the Log Uploader method within the My OSMC menu in the GUI or the ssh method invoking command grab-logs -A
then reboot. During the reboot process, pull out the ethernet adapter and only insert it once the Vero4K has fully restarted. See if it makes any difference.
today i’ve changed the cable, but the results are the same.
I really don’t know what to do now, because i’ve bought the adapter to migrate my HDDs to my new PC and stream my media over net. Frustrating…
Ok, thanks for your help!
I totaly forgot, that i have a switch in my network. I think it’s important for you to know!?
It’s a GS108Ev3 - 8-Port Gigabit ProSAFE Plus Switch from netgear and to be honest, i did install it and didn’t do any settings in it (because i really don’t know what settings to make). I think that this could be the problem?
ok, here you are:
Reading package lists… Done
Building dependency tree
ethtool
0 upgraded, 1 newly installed, 0 to remove and 10 not upgraded.
Need to get 107 kB of archives.
After this operation, 302 kB of additional disk space will be used.
Get:1 http://ftp.debian.org/debian stretch/main armhf ethtool armhf
1:4.8-1+b1 [107 kB]
Fetched 107 kB in 0s (271 kB/s)
Selecting previously unselected package ethtool.
(Reading database … 26875 files and directories currently installe
d.)
Preparing to unpack …/ethtool_1%3a4.8-1+b1_armhf.deb …
Unpacking ethtool (1:4.8-1+b1) …
Setting up ethtool (1:4.8-1+b1) …
