Hey all and a merry Christmas!
I recently upgraded from a Vero4k+ to a vero5 and have noticed that when browsing around in menus the “click” sound sometimes isn’t clean - it either pops or crackles… usually if I’m doing lots of clicks at once eg scrolling though a list.
Set up is vero5 - denon 4500h avr - TV with the avr pushing sound to speakers.
Sound is totally fine for films/YouTube etc so just wondering if it’s a vero5 UI issue? (Running confluence)
Would provide logs but unsure of what log to provide as nothing technically seems to be wrong?
Thanks in advance!
Hi, a standard log set is the first step to take I suggest.
The best way to get this information is for you to upload logs that demonstrate your problem. You can learn more about how to submit a useful support request here.
reproduce the issue
Please, also describe what remote control you’re using and a video with sound demonstrating what you experience with your evironment would be a wonderful help for us.
Enable keep audio alive and it should solve this
Thanks! That seems to have fixed it
