VeroV wifi card upgrade
Just bought a new VeroV and I am super happy about it. One thing I was wondering is if its possible to upgrade the WIFI card to something that supports WIFI7. Coming from a windows environment and appreciated the extra speed.
I mean the internal adapter not using an external usb one
The internal adapter is not socketed.
Ok well that kills it. Thanks for answering
Is there a specific reason you need a high speed?
WiFi won’t be an issue even for 4K UHD content
Speed not so much but 6Ghz yes. Less interference.
Got it. Unfortunately this isn’t possible on Vero V. It would be a compliance and warranty nightmare.
You could buy a USB adapter but unless you really need it..
Its all good. Didnt know if it was a socket or not and didnt want to open the box. Streaming 4k remuxes without any issues
