Odd one here, playing most files the remote reponse is fine, on a few its awful, multiple presses need to get info or just to stop. No idea why.
Media Info on a file that causes the problem
General
Unique ID : 47300289675529052568854186685223757818 (0x2395B4554A5BC5B893F869CC000167FA)
Format : Matroska
Format version : Version 4 / Version 2
File size : 2.38 GiB
Duration : 42 min 42 s
Overall bit rate : 7 973 kb/s
Writing application : mkvmerge v68.0.0 (‘The Curtain’) 64-bit
Writing library : libebml v1.4.2 + libmatroska v1.6.4
Video
Format : AVC
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, RefFrames : 2 frames
Codec ID : V_MPEG4/ISO/AVC
Bit rate mode : Constant
Bit rate : 7 830 kb/s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 25.000 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.151
Stream size : 2.32 GiB (98%)
Language : English
Default : Yes
Forced : No
Audio
Format : E-AC-3
Format/Info : Enhanced Audio Coding 3
Format settings, Endianness : Big
Codec ID : A_EAC3
Bit rate : 192 kb/s
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 kHz
Frame rate : 187.500 FPS (256 SPF)
Compression mode : Lossy
Stream size : 58.6 MiB (2%)
Language : English
Service kind : Complete Main
Default : Yes
Forced : No
Text #1
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Duration : 42 min 5 s
Bit rate : 81 b/s
Count of elements : 617
Stream size : 25.1 KiB (0%)
Language : English
Default : No
Forced : No
Text #2
Format : UTF-8
Bit rate : 83 b/s
Count of elements : 641
Stream size : 25.7 KiB (0%)
Title : SDH
Language : English
Default : No
Forced : No
And another that is fine
General
Unique ID : 285222919431908539320907962410789037108 (0xD693EFA69AF8F7411744D7F6E05CE434)
Format : Matroska
File size : 1 005 MiB
Duration : 40 min 24 s
Overall bit rate : 3 477 kb/s
Movie name : Batwoman - S03E13 - Are We Having Fun Yet
Writing application : mkvmerge v64.0.0 (‘Willows’) 64-bit
IMDB : tt8712204
TMDB : tv/89247
TVDB : 361315
Video
Format : AVC
Format profile : High@L3.1
Format settings, RefFrames : 4 frames
Bit rate : 2 835 kb/s
Nominal bit rate : 6 000 kb/s
Width : 1 280 pixels
Height : 640 pixels
Display aspect ratio : 2.000
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.144
Stream size : 819 MiB (82%)
Default : No
Forced : No
Color range : Limited
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Audio
Format : E-AC-3
Codec ID : A_EAC3
Bit rate : 640 kb/s
Stream size : 185 MiB (18%)
Language : English
Default : No
Forced : No
Text #1
Format : UTF-8
Duration : 40 min 16 s
Bit rate : 72 b/s
Count of elements : 708
Stream size : 21.4 KiB (0%)
Language : English
Default : No
Forced : No
Text #2
Format : UTF-8
Duration : 40 min 17 s
Bit rate : 80 b/s
Count of elements : 797
Stream size : 23.6 KiB (0%)
Title : SDH
Language : English
Default : No
Forced : No
Menu
00:39:53.000 : en:Credits
