new Vero 4k+ owner here. Managed to finally set up the device this week. First impression is great, seems to be what I was looking for.
HOWEVER, during first tests I noticed dropout issues even on low-bitrate files. WiFi is 5Ghz only and my router confirms a 5 GHz / ac / 80 MHz connection to osmc. My 5+ year old media box - that the Vero is intended to replace - reliably plays full bluray backups from the exact same spot.
osmc@osmc:~$ iperf3 -R -c 192.168.178.36
Connecting to host 192.168.178.36, port 5201
Reverse mode, remote host 192.168.178.36 is sending
[ 4] local 192.168.178.38 port 46815 connected to 192.168.178.36 port 5201
[ ID] Interval Transfer Bandwidth
[ 4] 0.00-1.00 sec 6.79 MBytes 56.9 Mbits/sec
[ 4] 1.00-2.00 sec 6.17 MBytes 51.8 Mbits/sec
[ 4] 2.00-3.01 sec 6.80 MBytes 56.6 Mbits/sec
[ 4] 3.01-4.00 sec 7.63 MBytes 64.4 Mbits/sec
[ 4] 4.00-5.00 sec 7.01 MBytes 58.9 Mbits/sec
[ 4] 5.00-6.00 sec 6.05 MBytes 50.7 Mbits/sec
[ 4] 6.00-7.00 sec 4.84 MBytes 40.6 Mbits/sec
[ 4] 7.00-8.00 sec 6.36 MBytes 53.3 Mbits/sec
[ 4] 8.00-9.00 sec 6.57 MBytes 55.1 Mbits/sec
[ 4] 9.00-10.00 sec 4.48 MBytes 37.6 Mbits/sec
[ 4] 0.00-10.00 sec 62.9 MBytes 52.7 Mbits/sec sender
[ 4] 0.00-10.00 sec 62.8 MBytes 52.7 Mbits/sec receiver
iperf Done.
Did iperf3 test and as you can see, the result comes out well below the expected 60-140 MBit/s for 5GHz connections, as stated in your how-to. Different positions around the TV didn’t change the outcome. All this would just be numbers to me if I could play my files, but it won’t even play my less demanding material without buffering. Full disc images only play in super-slo-mo without sound.
Because I was curious I also repeated the iperf3 test on my smartphone (a 2 year old 200$ android) - achieving 141 Mbit/s. This validates the performance of my old media box and it’s not surprising, as the TV is only ~5m from the router. So I’m afraid to say this points directly to the Vero being the cause. Any advice? Thanks!
