Please update vfs.libarchive to version 1.0.5
1.0.2 almost doesn’t work.
We are using the stable version recommended with Kodi v18.
Could you let us know the issues you are experiencing with 1.0.2?
I know that. As i write in kodi issue, vfs.rar works fine. Problem is with vfs.libarchive or if you have installed both… than libarchive is used for .rar files. It could be issue for someone.
I encountered the same issue and I think it needs to be addressed by the addon developer, since he himself said that vfs.libarchive should superseed vfs.rar and thus the first should be bypassed in favor of the second.
vfs.libarchive was fixed in developer repo months ago…
