I have some video stream doesn’t work correctly, no video is rendering, only the audio is playing. I also tried to download it and played it from local, still the same issue.
The only way to make it work correctly is to disable both OMX acceleration and MMAL Acceleration, and use software decoding.
I’ve searched the forum, found some similar threads, but they didn’t solve my problem. This video format is AVC High@L3.1, not sure RPi supports HW decoding of this format or not.
Here is the debug kodi.log http://paste.osmc.io/qumabinepe.dos
MediaInfo:
General
Complete name : D:\030001220055368513923105CF07DD27E67092-5CD0-7CA3-1979-5EE974596CF4.flv
Format : Flash Video
File size : 48.1 MiB
Duration : 3mn 24s
Overall bit rate : 1 976 Kbps
Tagging application : modified by youku.com in 20111202
Video
Format : AVC
Format profile : High@L3.1
Format settings, CABAC : Yes
Format settings, ReFrames : 5 frames
Codec ID : 7
Duration : 3mn 24s
Width : 1 280 pixels
Height : 536 pixels
Display aspect ratio : 2.40:1
Frame rate mode : Constant
Frame rate : 24.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : HE-AAC / LC
Codec ID : 10
Duration : 3mn 24s
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 44.1 KHz / 22.05 KHz
Compression mode : Lossy
Other info:
Device: RPi 2
Installation media: SD card
Connection: Wired
OSMC version: 2015.07-1
XBMC version: Kodi (15.1-RC1 Git:Unknown). Platform: Linux ARM (Thumb) 32-bit
Audio/Video Output: HDMI
