Streaming a file from Google Drive using a Web DAV source via another server… It’ll play for a while but then it freezes and kswapd0 is using a huge amount of CPU until i finally manage to stop it playing (or it crashes)…
logs are here :
https://paste.osmc.tv/mipurajeyu
i’ve since removed the kodi connect addon which i thought might be causing it… I’ve also stopped Sonarr from grabbing episodes and informing OSCM which was also going on at the time… I’m testing again now, just wondered if anything else stands out in the logs?
