On Vero4k+ at max resolution (4196x2160 @ 24hz) 99.9% of streaming content plays without issues. However, of late certain items in my library plays with heavy lags (slow-mo vid, audio out of sync) unless i downgrade resolution and increase refresh rates. Note that same content played well in past (also note they’re streamed via add-ons that shall not be named).
Are you talking about the resolution option in settings>system>display? If so that should be set at 1080p…
Click for more detail
We recommend people with 4K TVs set their user interface (UI) to 1080p. Kodi’s UI is not optimized for 4K yet and this can put unnecessary demands on your device and can lead to a suboptimal picture quality, as well as potentially cause other issues.
The settings we recommend are as follows…
Settings>System>Display>Resolution> 1920x1080p
Settings>System>Display>Whitelist> (empty) *
Settings>Player>Videos>Adjust display refresh rate>Always or On start/stop
Some televisions may also need, or benefit from, the following being set…
System>Display>Force 4:2:2 colour subsampling> (enable)
With the above settings your UI will be output in Full HD and your 4K content will be output in 4K.
*Information regarding the whitelist can be found here. If you have any doubt, feel free to upload some logs so we can verify that your settings are indeed correct.
If your UI is set to 1080p and your just talking about the resolution of the source file then likely the issue is your playing a format that the Vero doesn’t have hardware decode support for. It would be impossible to say for sure without seeing logs but if your running “things that can’t be named” that wouldn’t be something we can provide support for.
Yes, exactly. Did notice that @ 1080p issue never occurred and wanted an explanation as to why it was happening. Now I understand. Thanks.
PS: I did find some other threads that described “lagging” videos; this may very well be the resolution (pun intended).
