Experiencing a weird bug.
When I start to watch a recorded TV show (can’t see any pattern here - happens to random files - both manual recordings and scheduled recordings).
The video plays like its fast forwarding - this goes on for 3-5 seconds - then playback stops.
One common denominator is that the recordings that behave like this - have an obscure offset time.
It’s always set at 6.37.43 (6 hours, 37 minutes and 43 seconds)
See screenshot:
reboot the OSMC device
reproduce the issue
upload the log set either using the Log Uploader method within the My OSMC menu in the GUI or the ssh method invoking command grab-logs -A
Add the following line: deb http://apt.osmc.tv stretch-devel main
I noticed this a little while ago, daftly I presumed it was something to do with my TVHeadend setup, it was only on 2 recordings, if I fed them through FFmpeg with:
ffmpeg -i input.ts -c copy output.ts
it fixed the issue and the recording could be played back.
