Hi there,
I cant figure out how to solve this problem, maybe you can help me. The Vero is connected to a projector (1080p, 24hz) via HDMI. When a Video starts/stops, the signal is lost for a moment (blank screen, “looking for input source”). I am not 100% sure, but afair it started with Krypton. What I found and tried out:
- Neither changes in “Adjust display refresh rate to match video” nor “Sync playback to display” helps
- Audio output is passed through HDMI
- Deactivating hardware acceleration solves the issue, but surely the videos are unwatchable
- Both, “Render Method” in video settings and “Display Mode” in display settings are greyed out and set to “auto” and “windowed”
Here is a part of the log, I hope it helps to identify the problem and find the solution:
http://paste.osmc.io/bapecudoru.vhdl
greets and thanks
quan
